About the S5500-EI[SI] Command References
HomeSupportSwitchesH3C S5500 Switch SeriesReference GuidesCommand ReferencesH3C S5500-EI[SI] Command References-Release 2220-6W100About the S5500-EI[SI] Command References
Download Book
About the S5500-EI&S5500-SI Command References
The H3C S5500-EI&S5500-SI command references are part of the H3C S5500-EI&S5500-SI documentation set. They describe the commands and command syntax options available for the H3C S5500-EI&S5500-SI Switch Series Release 2220. The H3C S5500-EI&S5500-SI documentation set includes 10 command references:
Command Reference
Content
01 Fundamentals Command Reference
Covers the commands for logging in to and setting up the Switch. This command reference includes:
·     CLI
·     Login management
·     FTP
·     TFTP client
·     File system management
·       Configuration file management
·     Software upgrade
·     ISSU
·     Device management
02 IRF Command Reference
Covers the commands for configuring the H3C proprietary Intelligent Resilient Framework (IRF) technology features. It covers planning the switch roles in the IRF fabric, connecting the IRF links, and detecting and maintaining the IRF fabric.
03 Layer 2 – LAN Switching Command Reference
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes:
·       Ethernet interface
·       Loopback and null interface
·     Bulk interface configuration
·       MAC address table
·       MAC Information
·     Ethernet link aggregation
·     Port isolation
·       Spanning tree
·     BPDU tunneling
·       VLAN
·     Super VLAN (available only on the S5500-EI)
·     Isolate-user-VLAN
·     Voice VLAN
·     GVRP
·     QinQ
·     VLAN mapping (available only on the S5500-EI)
·     LLDP
·     Service loopback group (available only on the S5500-EI)
·     MVRP
04 Layer 3 – IP Services Command Reference
Covers the commands for configuring IP addressing, DHCP, IP performance optimization, ARP, DNS, IPv6 basics,UDP Helper, DHCPv6 and Tunneling. This command reference includes:
·       ARP
·       Gratuitous ARP
·       Proxy ARP
·       ARP snooping
·       IP addressing
·       DHCP server
·       DHCP relay agent
·       DHCP client
·       DHCP snooping
·       BOOTP client
·       IPv4 DNS
·       IRDP
·       IP performance optimization
·       UDP Helper
·       IPv6 basics
·       DHCPv6
·     IPv6 DNS
·       Tunneling (available only on the S5500-EI)
05 Layer 3 – IP Routing Command Reference
Covers the routing configuration commands. This command reference includes:
·     Basic IP routing
·     Static routing
·     RIP
·     OSPF (available only on the S5500-EI)
·     IS-IS (available only on the S5500-EI)
·     BGP (available only on the S5500-EI)
·     IPv6 static routing
·     RIPng
·     OSPFv3 (available only on the S5500-EI)
·     IPv6 IS-IS (available only on the S5500-EI)
·     IPv6 BGP (available only on the S5500-EI)
·     Routing policy
·     Policy-based routing (available only on the S5500-EI)
·     MCE
·     IPv6 MCE
06 IP Multicast Command Reference
Covers the commands for configuring Layer 2 and Layer 3 multicast services. This command reference includes:
·     IGMP snooping
·       PIM snooping
·     Multicast VLAN
·     Multicast routing and forwarding (available only on the S5500-EI)
·     IGMP (available only on the S5500-EI)
·     PIM (available only on the S5500-EI)
·     MSDP (available only on the S5500-EI)
·     MBGP (available only on the S5500-EI)
·     MLD snooping
·       IPv6 PIM snooping
·     IPv6 multicast VLAN
·       IPv6 multicast routing and forwarding (available only on the S5500-EI)
·     MLD (available only on the S5500-EI)
·     IPv6 PIM (available only on the S5500-EI)
·     IPv6 MBGP (available only on the S5500-EI)
07 ACL and QoS Command Reference
Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS technologies to improve network performance and network use efficiency. This command reference includes:
·     ACL
·       QoS policy
·       Priority mapping
·     GTS and rate limit
·       Congestion management
·       Congestion avoidance
·     Data buffer
08 Security Command Reference
Covers security feature commands. Available security features include identity authentication (AAA), access security (802.1X, MAC authentication, portal and port security), secure management (SSH), and attack protection (IP source guard, ARP attack protection, and URPF). This command reference includes:
·     AAA
·     802.1X
·     EAD fast deployment
·     MAC authentication
·     Portal
·     Port security
·     User profile
·     Password control
·     HABP
·     Public key
·     PKI
·     IPsec
·     IKE
·     SSH2.0
·     SSL
·     TCP attack protection
·     IP source guard
·     ARP attack protection
·     ND attack protection
·     URPF
·       SAVI
·     Blacklist
·     FIPS
09 High Availability Command Reference
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes:
·     Ethernet OAM
·     CFD
·     DLDP
·     RRPP
·     Smart Link
·     Monitor Link
·     VRRP (available only on the S5500-EI)
·     Stateful failover (available only on the S5500-EI)
·     BFD (available only on the S5500-EI)
·     Track
10 Network Management and Monitoring Command Reference
Covers the commands that help you manage and monitor your network, for example, manage system events, sample packets, assess network performance, synchronize the clock for all devices with the clock in the network, supply power for attached devices by using PoE, and test network connectivity. This command reference includes:
·       Ping, tracert, and system debugging
·     NTP
·     Information center
·       SNMP
·     MIB
·       RMON
·     Port mirroring
·       Traffic mirroring
·       NQA
·       sFlow
·     IPC
·     PoE
·       Cluster management
·     Stack management (available only on the S5500-SI)
·     CWMP (available only on the S5500-EI)
